will 342s fit a V6 carrier?
I think you can get one from New Era performance. It goes between the ring gear and the carrier. I would highly recommend getting 2 series 3.42s though instead of getting the spacer.
the spacer is a 'last resort' situation.The spacer has to be 'perfect',flat and parallel.Any variance from 'perfect' will produce a varying lash situation.Also with a spacer,two potentially sliding surfaces have been introduced which could cause ring gear bolts to lose their torque.
Im looking to put a 2 series carrier into my s10 with 342 gears. Is this what I would need
http://www.speedwaymotors.com/p/7534...ar-Spacer.html
