Axle twist question
Old Nov 13, 2007 | 08:23 PM
critter's Avatar
Default Axle twist question
How much do you let your axles twist before your replace them?
Does anyone swap sides and twist them back these days?
FWIW, this is a bottom 10's car. I can't believe it is twisting the axles. But then it stripped a new Strange 4.88 gearset on the fourth launch.
Old Nov 13, 2007 | 11:56 PM
Scott@DrivelineSolutions's Avatar
LS1Tech Sponsor
I would say it's time for a set of 35 spline axles. I am guessing you are running a 12bolt with 30 spline axles.
Old Nov 14, 2007 | 06:46 AM
critter's Avatar
LOL! Moser 12 bolt with Moser axles, which I thought were more than 30 spline, but don't recall and am not at home. At this point I would prefer a 9", but new axles are a hell of a lot cheaper than a whole new rear end, even if I had to buy a new spool to get finer splined axles.
But you are in the business - how much twist before I scrap the axles?
Old Nov 14, 2007 | 11:47 AM
LS1Tech Sponsor
Don't know, every thing relies on how the shaft was produced. You can get 35 spline axles and a spool for your 12 bolt now. I have cars running high 8's and pro gears when they run that fast.
Old Nov 15, 2007 | 03:28 PM
mikenews's Avatar
Ya put them in the other side to twist em back, and give me a call after your first run I have tow truck!
Old Nov 15, 2007 | 03:32 PM
2002_Z28_Six_Speed's Avatar
Aha! I think forged metal gets more brittle after it has been perm. distorted. So it is only a matter of time for the hardened metal to fail.
Old Nov 17, 2007 | 09:39 AM
studderin's Avatar
I twisted the crap out of my 35spine axles, my rotor started rubbing on the cliper making noise.
Old Nov 17, 2007 | 12:58 PM
RA4926's Avatar
arnt the driver and passenger axles different lengths?
Old Nov 17, 2007 | 02:06 PM
DAVESS02's Avatar
What kind of power/times are you running to twist 35 spline axles?
Old Nov 23, 2007 | 10:17 PM
studderin's Avatar
330whp, I run 12's
https://ls1tech.com/forums/showthrea...60#post8099318
Old Nov 24, 2007 | 08:10 PM
monzaz's Avatar
Default 12's and twisting???
Please let me know what kind of axles you have so I can stay clear of them...lol
I tested stock gm axles 30 spline 8.5 s-10 rear to 11.30's so far pulling the fronts and 1.48 60 foots and not a thing bent twisted etc for 5 years now. This is not a super fast car but...we just stick in diffs under tester vehicles and beat the crap out of them to see what GM is putting out in vehicles these days.
You sure you did not get a defective set??? I would call your manufacturer on that. Jim
J D Race.com
Old Nov 25, 2007 | 08:03 PM
chrismorales75's Avatar
I would replace a twisted axle as soon as I see it is twisted.
You can put 35 spline axles in a 12 bolt but I hear the bearing area is thin and isn't that great of an idea.
I ran 33 spline axles and a spool in a nitrous assisted car in the 9.30 range and never had a problem, although I had pro gears and strange axles.
