What U joint with Moser 12 Bolt?
Want to use the stock driveshaft with a Moser 12 bolt so what U joint/adapter would I need to use the 1350 yoke? Also, is this unit a direct bolt in or do I need anymore adapters etc..
Thanks
Thanks
Re: What U joint with Moser 12 Bolt?
There aren't "adapters" to use a 1310 yoke to a 1350 yoke. To use the driveshaft with a 1350 yoke on the Moser you'd have to have the 1310 yoke on your stock driveshaft cut off and a 1350 yoke welded on.
A direct bolt in would be to just have the Moser shipped with the 1310 yoke.
