RAM 402/610 setup is awesome Thanks FMS
does it shake the car on take off if you dont get the rpm's up?(easy take offs)will it hold a 430hp car on et streets? on my centerforce clutch if i dont get the rpm's up to 1,500 on easy take offs it shakes the car bad. thank you, mike c.
Mike...so far it does not shudder at all. Occaissionally it will "bite" once if you let the clutch out a lil too fast..but no percieveable shudder. Funny because Im so used to the shuddering I am letting the clutch out slower than I should. Ill have to get used to driving normally again, lol.
I am fully expecting it to hold My 600+ rwhp on ET drags on occaision, and I believe Allan uses it in his 346 solid roller car running mid tens. So I think it will serve your purpose well.
Serial..Im using the adjustable master I got way back when I bought my CARTEK setup. It has held up well so far. My CARTEK lasted three passes. I then used an Old SPEC stage III carbon disc with the CARTEK PP and it lasted me a year running mid to high 10s in a heavy car. I really think this clutch will last a while.
Got excellent service from Allan at FMS. Ordered the RAM 402/910 scintered iron disk setup and got it a few days later, installed in my garage the next day.
Man, for a clutch that has that much holding power it sure is streetable. I have no chatter...none! The flywheel that came with it was very nice as well...sure smooths out the idle. Definately the best money Ive spent on a clutch. I definately recommend this setup..even for street duty. Wooohooo! <img border="0" alt="[cheers]" title="" src="graemlins/gr_cheers.gif" />
