Rearend questions inside??
Old Jun 23, 2003 | 04:43 PM
ExtremeZ28's Avatar
Default Rearend questions inside??
I have recently purchased and recieved my Moser 12-bolt rear end so i no longer need my 10 bolt. I have a friend who has a 99 V6 Firebird who wants my rear and driveshaft. Two questions, is all my stock stuff going to fit on his car and also if he takes his backing plates off his car to give to me for my new Moser is it going to fit??
Thanks for any help
Jay
Old Jun 24, 2003 | 10:20 AM
ExtremeZ28's Avatar
Default Re: Rearend questions inside??
ttt,any help is appreciated...also what weight gear oil should i use in my 12 bolt??
Thanks again
Old Jun 24, 2003 | 12:08 PM
Scalpel's Avatar
If it's the same gen F-body it'll all fit. They have the same rear as you did stock. The driveshaft will work too. Fluid - use 75W90, Moser says to use non-synthetic lube b/c dino oils have better shock abosorbing ability against sheer, etc.
