Difference between stock & TA cover
Old Jun 23, 2003 | 09:24 PM
jpz28's Avatar
Default Difference between stock & TA cover
What is the difference between the stock rearend cover and the TA rearend cover?.....
Old Jun 23, 2003 | 09:48 PM
trackbird's Avatar
Default Re: Difference between stock & TA cover
The TA cover is much heavier (stronger) and made of aluminum. It also has 2 bolts that are screwed in until they contact the main caps (that support the bearings in the rear end) to support the bearing caps and reduce ring gear wear due to "cap deflection". Not a bad upgrade for durability. However, if you are launching on slicks at 6000, don't bother....just buy the 12 bolt....the TA cover helps, but it is not a "miracle cure". Just my thoughts.
Good luck!
Old Jun 24, 2003 | 02:22 PM
AshF's Avatar
By "TA cover" do you mean Trans-Am cover or some aftermarket company?
Old Jun 24, 2003 | 02:34 PM
trackbird's Avatar
TA performance cover, also sold by Jegs, Lingenfelter and several others....
Old Jun 24, 2003 | 03:51 PM
AshF's Avatar
Thanks
Old Jul 1, 2003 | 11:53 PM
Jpr5690's Avatar
see what a smart guy thats the only time ive heard a someone actually explain the usefulness of that mod. most just call it crap and move on. now that u said that it makes me wanna buy one
Old Jul 2, 2003 | 02:28 PM
trackbird's Avatar
I'm looking to add one soon and I may do a differential cooler at the same time.
Kevin
