need serious help....quick!
Old Jan 14, 2003 | 01:08 PM
Matt98ls1's Avatar
Default need serious help....quick!
last night my car went over an enormous bump...didnt see it in the road, had no idea it was there, but apparently my car felt it. i checked that night but couldnt really see, so i went to check this morning, and it seems as if that bar that goes under the differential is bent. the bump pushed it towards the front of the car a bit, and its not directly under the differential anymore......any harm?? how can i fix it?? please help
Old Jan 14, 2003 | 09:04 PM
Ragtop 99's Avatar
Default Re: need serious help....quick!
Take a look at it - did you bend the bar or the mounts? maybe its time for a new swaybar. <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
Old Jan 14, 2003 | 11:25 PM
SS SLP2's Avatar
Check the panhandle bar ?? ( the bar which centers the rear under the body ) get a thrust line alignment ( about 50.00) to be sure rear is stright under body ( thrust angle should be less than 0.13 deg. any more and car will walk sideways if pushed hard off the line
for more info on thrust come see
http://kickme.to/jgruggles
