Rear-end weights - Post what you have
LS1Tech Sponsor
3.50 35 spline Pro Gear with a steel spool. The caliper brackets are alot lighter than stock.
The ring and pinion gear werent mentioned??
Also what kind of differential?? like a spool or torsen? etc..
lastly the strange caliper brakes, how light are those compared to OEM rotors and stock calipers?
because if all of this is what I wanna hear, this is a differential WORTH spending $$ on on
LS1Tech Premium Sponsor
this particular car has Delrin plastic bushings. Delrin is a natural lubricant vs. steel. this setup as well as my bolt-on drag arb version are available with Delrin, bronze oil-lite, or roller bearing. the pictured assy is available in kit form, and the bolt-on version fits my 9 inch and some other rears.
Moser M9 Housing with ends welded on and torque arm brackets welded on, minus control arm brackets. 48.5 lbs.
We had the housing above made for an '06 GTO, and we need to locate the lower control arms ourselves. This is why the above rear does not have lower control arm brackets already installed on it. Bob
#32
are you sure about that? I havnt really handled a spool, Bit I think you mean the bare spool was 8 not what it saved over a turtrac.
When me and SSshawn@newera put the 4:30s in my car. The true trac was really heavy, he warned me about when it poped out to be ready to hold good
and I wasn't ready for that thing almost droped it, at it was like 6ft up on the lift I looked it up when we posted about it on a local site
"A truetrac with ring gear bolted on weight 56.330 pounds"
I cant see how a spool with a ring gear would weight 48#s
#35
Oops, I forgot about this thread..
I haven't installed the 9" yet, but I already removed the 10 bolt. It was ~157 full of fluid with no brakes.
But everyone already knew how much a stock rearend weighed.. sorry that doesn't help..hah
#37
Quick Performance 9" Housing
Bare Housing with T/A Bracket = 75 lbs
Moser 31 spline Axles with Bearings = 18/19 = 37 lbs
Strange 'S' Case, Nodular Iron
Aluminum Daytona Pinion Support
Detroit Locker (Large Bearing, 3.25")
3.89 Gears
Billet Steel 1350 Yoke
Assembled Center Section Total = 71 lbs
Still to come:
LT1 Brake Backing Plates = ?
LT1 Sway Bar w/Brackets = ?
3.89 Gears
Still to come:
#39
OLd moser 12 bolt w/33 spline eaton posi
4.11 gears
alum cover
4 channel abs
backing plates and caliper mount
215 lbs minus the spider gears, because they flowed out with the oil, in 2000 little pieces...
NEW
Strange 9" Housing, 3.250" .250 Wall axle tubes, internal gussets and back braced. Narrowed 4" per side for 8" total
My own custom 4130 lca, coil over, PHR and torque arm brackets.
Moser alum case
35 spline strange axles
steel pinion support
4.57 gears
steel spool
aluminum caliper mounts
154lbs.
4.11 gears
alum cover
4 channel abs
NEW
Moser alum case
4.57 gears
steel spool
154lbs.
