U Joint End Play
Old Dec 12, 2007 | 08:17 PM
scottso's Avatar
Default U Joint End Play
Should the rear U joint have any end play? I can get a little side to side movement - looks like the end caps move under the straps.
Old Dec 12, 2007 | 09:26 PM
Jawsgear's Avatar
Absolutely no end play on your ujoint. If there is your yoke is most likely worn between the ears and needs to be replaced.
Jeff
