ford 9" soilid pinion spacer help
i know normally you set a preload on the pinion in inch pounds with a crush sleeve and shims.
with a solid pinion spacer, doesnt it just get torqued down, or is there other measures required to install this piece?
ive searched the net and only found info on crush sleeve installation.
thanks!
thanks!
Yes in order to set the preload you have to add and subtract shims from the spacer kit and make sure you get the proper preload or it will be just like over crushing or not crushing a crush sleeve which will lead to problems,
Jeff
Jeff
