lockup problems...
Old Jan 27, 2003 | 10:34 PM
B18B1LS1's Avatar
Default lockup problems...
I went to the track Saturday and made about 10 NA passes. Now after about 10 minutes of driving my converter unlocks and won't lock back up, any ideas? The only tuning I have is Hypertech for shift points. Prior to this it was a flawless converter. I'm stuck with manually locking it up and that sucks, and I'm not even sure it's okay to be doing that. Any help would be greatly appreciated!
Jeffrey
Old Jan 28, 2003 | 12:24 AM
SS SLP2's Avatar
Default Re: lockup problems...
Like problem on y2k 5.3 truck,truck in trans shop for a week ,unable to locake problem, to GM for a day for reflash pcm, no help, find under drive pulley coming apart- wobbleing, replact with stock pulley AND all lockup problems go away, going to replace stock pulley with new under drive when weather warm up and see if all stay good
good luck
Johnny
Old Jan 28, 2003 | 04:26 PM
B18B1LS1's Avatar
I still have my stock pulley. Any other ideas, anyone?
<small>[ January 28, 2003, 05:25 PM: Message edited by: B18B1LS1 ]</small>
Old Jan 31, 2003 | 08:55 PM
Nagash01WS6's Avatar
How does your fluid look / smell???
Does it smell burnt at all???
Does it chatter any when you manually lock it up?
Old Feb 1, 2003 | 09:31 AM
B18B1LS1's Avatar
The fluid is fine, I change it regularly. Doesn't look or smell bad at all. Still locks up perfect manually.
Old Feb 1, 2003 | 06:59 PM
WILWAXU's Avatar
My car started this after the 12 bolt (3.73's). But it was a little different. Mine jumped in an out of LU.
Ed Wright Tuning cured it and TM <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" /> .
Old Feb 2, 2003 | 06:05 PM
B18B1LS1's Avatar
After paying more attention to mine and not locking it up so soon manually I noticed it is unlocking and locking up as I drive. Any idea what Ed changed? Thanks.
Jeffrey
Old Feb 4, 2003 | 07:38 PM
WILWAXU's Avatar
Not sure.. I bought the tuning pre-LS1edit. Worked flawless, so I haven't messed with it.
Drop a post in the Computer Tuning section. Those guys can help you out.
