ADJ Master clyd
Old Feb 7, 2003 | 11:15 PM
blkonblk00ss's Avatar
Default ADJ Master clyd
I called Thunder Racing today and they told me that if I ran a Spec stage 3 that i would have to run a adj master clyd, Is this true or not I don't wont to run It i was going to keep my stock one in.
Old Feb 8, 2003 | 12:57 AM
John98LS1's Avatar
Default Re: ADJ Master clyd
i need to know too!!!!! i have a 98,, i wounder if you can use the same master but get a 02 slave, can anybody help? thanks
Old Feb 8, 2003 | 10:22 AM
OneQuickSS's Avatar
Im not sure on that, but Ive heard that in the past. If I were you, I would go ahead and upgrade to the adjustable one. Ive heard that you can make your stock one adjustable or something of that nature! The problem with the stock one is that the clutch fluid gets so hot, it boils not allowing the shaft on the clutch master to function properly. The line for it has a restrictor on it where the base of the problem is. It doesnt get the kind of flow that it needs, not allowing the fluid to flow correctly causing it to stick to the floor. I had the same problem when I went to the track for the first time with all stock clutch system. So with the pedal sticking, it would make it almost impossible for me to speed shift! If you have a car made before 2001, I would upgrade the clutch disk, pressure plate, throw out bearing, slave, and clutch master. In '01 and '02 cars, I think they upgraded the slave and put in a ZO6 clutch. Well I hope that helps and Im sure if I made any mistakes, someone will correct me.
Old Feb 8, 2003 | 11:56 AM
John98LS1's Avatar
were can i get a 2001+ master and slave over the net
Old Feb 8, 2003 | 01:45 PM
MIGHTYMOUSE's Avatar
lol our clutch fluid does not boil!
why not call the people that make the clutch?
1800 828 4379 Dave Norton
spec clutches have never had adjustable masters be mandatory, but an option.
i have an adjustable stock master instead of the mcleods that are not doing so well these days... they are easy to make adjustable
the pedal on the stock clutch sticks because of the stock pressure plate fingers being weak.
paceparts.com or sdpc can get you stock hydraulics cheap (check to the right)
Old Feb 8, 2003 | 06:05 PM
bomax's Avatar
How to make your master adjustable:
http://www.ls1camaro.net/article.php...&mode=&order=0
Old Feb 9, 2003 | 12:51 AM
John98LS1's Avatar
soo wait i can use my 98 master and just get a 02 slave??? give me a straght answear. also is that ram master good to use on a spec??? thanks
Old Feb 9, 2003 | 06:43 PM
John98LS1's Avatar
ttt
Old Feb 9, 2003 | 08:00 PM
John98LS1's Avatar
were can i get 01+ model MC and SC thanks.. i need just the gm kind not after market. thanks
Old Feb 10, 2003 | 12:57 AM
John98LS1's Avatar
Old Feb 10, 2003 | 05:07 AM
99ZEOD's Avatar
Coolguy, check your other post. Do yourself a favor and get an adjustable or make yours adjustable. Trust me.
Old Feb 10, 2003 | 05:31 PM
wow bomax that article looks familiar <img border="0" title="" alt="[Roll Eyes]" src="images/icons/rolleyes.gif" />
thanks for taking the credit dude.
Old Feb 11, 2003 | 12:54 AM
John98LS1's Avatar
I already oredered a 02 model GM master and slave. thanks
Old Feb 11, 2003 | 12:56 AM
John98LS1's Avatar
hey but thanks for the help dude
Old Feb 13, 2003 | 08:14 AM
Joe Kizzire's Avatar
Resident Grump
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by MIGHTYMOUSE:
<strong> wow bomax that article looks familiar <img border="0" title="" alt="[Roll Eyes]" src="images/icons/rolleyes.gif" />
thanks for taking the credit dude. </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">I wonder who thought of making the stock master cylinder adjustable???
