Moser 9" options
Whatever you do, order your rear through Bob at EPP. He will do his best to take care of you if you ever have a problem.
Jeff
Jeff
Didn't even think about the anit-roll bar brackets. Obviously get the lca brackets pretty much a must and why not a drain plug too right. Powerder coating is nice but discretion on the buyer. We'll see how it adds up. I say skip the backbrace unless some serius drag racing and get the iron center for strength. I guess the only thing I am unaware about is the anit-roll bar brackets
The Moser anti-roll bar brackets are designed to work with the BMR Xtreme anti roll bar. This anti roll bar makes one heck of a difference in how a car launches off the starting line. We preload the right side of the bar, and then the car does not launch and lean to the right when coming out off the line. Bob
I would at minimum get the drain plug and relocation brackets. It would be such a pain in the *** to change the fluid if you didn't get it. I also had to weld UMI relocation brackets on my Moser 9" because i purchased my rearend before it was offered as an option. You may also consider the extended stud option if you plan on running drag wheels/slicks on the car.. i forgot when i ordered mine and had to buy a set of ARP's..no biggie tho.
One thing I was thinking about and if someone could chime in about is hard corner acceleration? With the spool is it possible to do this? I mostly drive fairly good on the street but do like to get a lil wild at times? Does it make sense that it would be harder on the actual axles, bearings, etc to go flying around a corner or sideways and what not? Just curious, than the spool would be most likely out for roadracing than. Not that I car b/c I don't do it, more of curiousity here? Anyone with this experience?
this is just my opinion however. i drove my friend's car with a spool and didn't like it at all. since your car will remain a street car, go with a locker if you have doubts about the truetrac.
