Will this Master work ???
Old Feb 9, 2003 | 09:31 PM
John98LS1's Avatar
Default Will this Master work ???
will a ram adj master work on a spec stage 3 clutch??? also should i still do the drill mod even if i get a better master ??? thanks
<small>[ February 09, 2003, 10:01 PM: Message edited by: coolguy ]</small>
Old Feb 9, 2003 | 11:51 PM
John98LS1's Avatar
Default Re: Will this Master work ???
Old Feb 10, 2003 | 12:04 AM
John98LS1's Avatar
does it make a big diffrence if i get a adj master (Ram) form the 2001+ gm master,,, would it be fine if i went with a gm 2001+ model master???
Old Feb 10, 2003 | 05:00 AM
99ZEOD's Avatar
Yes, the Ram master will work fine for you. If you get another master from GM it won't be adjustable. You need to have an adjustable master so you can change you engagement point for the aftermarket clutch. Also, do the drill mod while your in there. Every little bit helps.
Old Feb 10, 2003 | 11:03 AM
John98LS1's Avatar
I ordered the 01=master and slave.
