To Drll or not to Drill
Old Feb 10, 2003 | 11:09 PM
John98LS1's Avatar
Default To Drll or not to Drill
Iv heard good and bad thing from doing the drill mod. Im putting a spec stage 3 clutch in my car with a 02 slave and a ram adj master. should i still do the drill mod?? also do i ave to bleed the systeam if i dont do the drill mod?? thanks
<small>[ February 11, 2003, 12:30 AM: Message edited by: coolguy ]</small>
Old Feb 11, 2003 | 09:05 AM
John98LS1's Avatar
Default Re: To Drll or not to Drill
Old Feb 11, 2003 | 09:13 AM
Rayo's Avatar
Since you are installing a new hydraulic system...I say do the drill mod...you will already have everything apart...the drill mod will take about 5 minutes to do...and yes you still need to bleed the system since you are installing a new clutch hydraulic system...
Rayo
Old Feb 11, 2003 | 04:19 PM
xaon's Avatar
I've got the same clutch in my car, but running stock '01 hydraulics.
I did not do the drill mod on mine, but if I were replacing the master cylinder like you are, I most definately would have.
I am not seeing any ill-effects from not doing the drill-mod on my car so far, but if you've already got it out, better safe than sorry.
Old Feb 12, 2003 | 12:46 AM
John98LS1's Avatar
well i need to here from people who havent done it. I want see what they say about it
Old Feb 12, 2003 | 01:04 AM
John98LS1's Avatar
what is the best way in DETAILS to bleed the hydro systeam?? thanks
<small>[ February 12, 2003, 01:38 AM: Message edited by: coolguy ]</small>
Old Feb 12, 2003 | 11:12 AM
John98LS1's Avatar
Old Feb 12, 2003 | 04:36 PM
2001CamaroGuy's Avatar
DRILLLL!!! its a really good mod and its not hard. You will kick yourself if you don't.
Old Feb 12, 2003 | 10:43 PM
John98LS1's Avatar
whats the best way to bleed the systeam?? thanks
Old Feb 13, 2003 | 09:09 AM
John98LS1's Avatar
Old Feb 13, 2003 | 10:39 PM
John98LS1's Avatar
ttt
Old Feb 15, 2003 | 11:30 AM
Boosted LS1's Avatar
Somebody tell me please, what is this drill mod that your talking about? Thanks.
Old Feb 15, 2003 | 11:50 AM
99ZEOD's Avatar
It removes a restriction in the hydraulic line where it connects to the master cylinder. It's fully explained here http://www.installuniversity.com/
Old Feb 17, 2003 | 10:56 PM
John98LS1's Avatar
ttt
