Install Kit Necessary When Switching to 4.10s?
I'm considering purchasing a set of Motive 4.10s, and noticed that there is an option to purchase the gears with a "Master Install Kit". Would this be money well spent? I'm not even sure what is included in the install kit, but if it will be a valuable improvement over the gears alone, I wouldn't mind saving up the extra cash.
Thanks,
Josh
Thanks,
Josh
Re: Install Kit Necessary When Switching to 4.10s?
i guess it depends on you. i just put pinion bearings in when i had my gears installed. and my car had 46000 miles on it. it's still going strong.
my carrier bearings were pretty bad and the car only had 25,000 miles on it, axle bearings were fine, with an M-6 I'de recommend atleast the full kit.
