Strange U1603 questions
Also am i supposed to have to press the U-Joint into the yoke? I cant get the joint into the yoke by hand...
a 1350 series u joint will require a small amount of clamping force to get the u-joint into the 1603 yoke. it was manufactured with very close tolerances to ensure no slop or runout of the u-joint/driveshaft. if you have no way o clamping it efficently, then use a poly type hammer to tap it in evenly a little bit each side until it seats.
kind of a pain, but thats what you get when you call summit and tell them to send you a yoke for a 9inch with 1350 u-joint.
