pinion angle?
Old Feb 24, 2003 | 10:12 PM
TJ's Avatar
TJ
Default pinion angle?
what are you guys setting the pinion angle at on adjustable torque arm cars? i will be doing a street strip type of deal. i need the best of both worlds. i want it to run good on the track and not sling a u joint on the street.
thanks!
Old Feb 24, 2003 | 11:06 PM
Gustin's Avatar
Default Re: pinion angle?
For a street strip set up you only want about 4-5 of total pinion angle
So what you need to do is measure the angle of the drive shaft (which should be around 2 deg positive). So if the drive shaft measures 2 deg positive you want about 2 deg negative on the rearend pinion. Add -2 + 2 = 4 deg of total pinion angle.
Hope that helps,
Sean
Old Feb 26, 2003 | 11:03 PM
SS SLP2's Avatar
IF heavy mod I think 2-2 1/2 neg.
lite mods 1-1 1/2 neg.
my .02
