twisting axles
Old Mar 13, 2008 | 10:55 AM
ndfrsd6's Avatar
Default twisting axles
I have a 12 bolt strange and found out my axles were twisted ! the rear end has a spool 4.56 richmond gears ,now the car makes close to 500 rwhp 6 spd and is in the low 3000 range for weight .strange did warrenty them but i dont want to go 9 in yet even though it's probally coming ! any one else have the same trouble
thanks guys
Old Mar 13, 2008 | 11:25 AM
venomhp's Avatar
I did the same to a 12 bolt, broke the spot welds on the diff. but if you have a new one coming from warranty, id say its a good time to sell that now brand new one and upgrade. was it the housing or the shaft that was twisted?
Old Mar 13, 2008 | 11:27 AM
ndfrsd6's Avatar
both shafts were twisted the spline going into the spool was ok the bottom half was of them was twisted........
Old Mar 13, 2008 | 11:39 AM
ndfrsd6's Avatar
here's a pic
Old Mar 13, 2008 | 01:56 PM
bigsticksupra's Avatar
seems like the cars with spools are twisting them. how many spline axles were they?
Old Mar 13, 2008 | 05:34 PM
venomhp's Avatar
I cant see the pic, did you have upgraded shafts?
Old Mar 14, 2008 | 07:52 AM
RA4926's Avatar
if your twisting axle's, upgrade your axles. if your twisting 33 spline axles in a 12 bolt, your going to twist 33 spline axles in a 9 inch. the reason a 9 inch is "better" is because of the extra .125" diameter of the ring gear and some argue the design of the housing.
Old Mar 14, 2008 | 10:26 AM
ndfrsd6's Avatar
Yes they are 33 spline and the shafts are upgraded ! i can't get the pic to upload sorry
