just looking for the right answer
Old Mar 15, 2008 | 10:21 PM
austin21's Avatar
Default just looking for the right answer
ok, I did a search today and couldnt come up with a yes or no answer so if anyone could help that would be great .But my question is can an 8.5 10 bolt rear end be used in a 98 + fbody ?
Old Mar 15, 2008 | 10:55 PM
35th SS's Avatar
just remember 8.5 10bolts rear are use on gm trucks silverado and gmc.someone will chime in.
Old Mar 15, 2008 | 11:13 PM
RA4926's Avatar
arent 8.5" leaf spring? also, im sure the housing is longer. would require a good welder/fabricator to get it to work.
Old Mar 15, 2008 | 11:45 PM
ssvert99's Avatar
LS1Tech Premium Sponsor
uhhhh... torque arm mount? i'd have to say... NO. or good luck anyway. not that it can't be done, but not too cost efficent.
Old Mar 16, 2008 | 02:06 AM
Scott@DrivelineSolutions's Avatar
LS1Tech Sponsor
I have a local customer that brought me a 8.5 10 bolt made to fit his LT1 car. The TA mount was brazed on the cast iron and the brackets were taken off of a old 7.5 and rewelded on a 8.5. The tubes were cut to correct length and some Ford stlye ends were installed. So far I have heard the car puts down almost 500 to the tires. No issues yet with the brazing but like everything else it's just a mater of time.
