Rear End Whine
Old Jul 23, 2003 | 10:07 AM
WS62GO's Avatar
Default Rear End Whine
My Car's rear end whines/squeals when I back into garage.
Anyone had similar problem?
Old Jul 23, 2003 | 09:06 PM
pascal's Avatar
Default Re: Rear End Whine
is it the rear or trans. whinein'???
Old Jul 24, 2003 | 01:34 PM
ngozer's Avatar
my rear has been doing the same thing for about the past 5000 miles it also does it when i go around sharp turns slowly. it did it with my stock 3.23's and also with my 4.10's. i just thought it was my posi.
Old Jul 24, 2003 | 01:55 PM
timelord's Avatar
Check your C Clips,it happened to me[and tight turns]made a hell of a noise!!!!
Old Jul 24, 2003 | 03:00 PM
JeffT's Avatar
C-clips are either in or out no real in between. It's probably just your traction unit leting you know it's working right. If it's a clutch type you can add some friction modifier to help out some.
Old Jul 27, 2003 | 09:46 PM
Jpr5690's Avatar
hell 02 take it in under warrenty it sounds like someting with gears or ds i also had thatpreblem after replacing my carrier it was a unlubed seal in the back the pumkin and i think the carrier berring
Old Jul 27, 2003 | 10:42 PM
destroyerSS's Avatar
how many miles are on your rear? Do a rear end service and check for any metal. If all looks good use synthetic gear oil & posi additive. I recommened using FORD posi additve it works great but smells like ****.
Old Aug 6, 2003 | 06:29 PM
ggr12's Avatar
My rears also makin some whining noise. only at 30+mph decellerating. goes away when throttle is applied. any opinions to what this may be?
