racing in overdrive?
Old Mar 4, 2003 | 06:45 PM
BigPlanTransAm's Avatar
Default racing in overdrive?
i was playing around with a calulator and it seems if i were to get 3.73 rearend gears i would max out at about 123 mph. what if i could go faster but ran out of gear? if i were to get a high performance tranny rebuild would that make it safe to race in overdrive to gain that extra gear? i dont want to spin the motor past 6,000 rpm so would i be screwed and have to move down to 3.42's or is there some other solution. im not interested in resizing my wheels either. im just wondering if i should go with 3.42's or 3.73's when i get a new 12 bolt. i would really like to get the 3.73's but i dont want to have to switch them out for 3.42's so any other suggestions would be helpfull. thanks in advance guys.
Old Mar 4, 2003 | 06:53 PM
WJ SOM SS's Avatar
Default Re: racing in overdrive?
Using OD is not the answer. WJ. <img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" />
Old Mar 4, 2003 | 06:58 PM
Cool28's Avatar
Tire Smoking Tranny Blowing Director
I 2nd that. I would get a taller tire before Id use OD.
Old Mar 5, 2003 | 10:26 AM
Dave Rockwell's Avatar
I'm assuming your running a 4L60E, why wouldn't you run in O.D.? <img border="0" title="" alt="[Eek!]" src="gr_eek2.gif" />
Old Mar 5, 2003 | 11:08 AM
Chris99WS6PWTMET's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by Dave Rockwell:
<strong> I'm assuming your running a 4L60E, why wouldn't you run in O.D.? <img border="0" title="" alt="[Eek!]" src="gr_eek2.gif" /> </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">First off, the 4L60E will not shift into OD at WOT and secondly the clutch packs in 4th are not as strong as the others. The ONLY thing I do in OD with my Pro Yank is cruise.
Old Mar 5, 2003 | 08:28 PM
B18B1LS1's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by Chris99WS6PWTMET:
<strong> </font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by Dave Rockwell:
<strong> I'm assuming your running a 4L60E, why wouldn't you run in O.D.? <img border="0" title="" alt="[Eek!]" src="gr_eek2.gif" /> </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">First off, the 4L60E will not shift into OD at WOT and secondly the clutch packs in 4th are not as strong as the others. The ONLY thing I do in OD with my Pro Yank is cruise. </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Due to my poorly thoughtout nitrous setup I have to finish the 1/4 in OD until I swap my gear. I have gone into OD at WOT hundreds of time. I know I'm on borrowed time doing it but it WILL go.
Jeffrey
Old Mar 5, 2003 | 10:59 PM
RPM WS6's Avatar
LS1Tech Administrator
Community Influencer
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by BigPlanTransAm:
<strong> i dont want to spin the motor past 6,000 rpm </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Why not? You won't really start to see any real increase in wear until above 6400 or so. I'd say you'd be safe till about 6600 before really increasing bottom end wear. This is of course assuming you have aftermarket valve springs. You should not rev the stock springs past 6200.
There is really no need to limit yourself to 6000rpm shift points.
Old Mar 6, 2003 | 12:09 AM
blown 346's Avatar
I would just get a built tranny. They seem to hold up the strain and the heat. Even though heat is the tranny's enemy, they are built for it. When I get my stage 3 race prepped trans I'm going with the 373's.
