Not sure how to shift race style
you pull or push the shifter toward the next gear while you are acelerating still, not so hard that you force it out of gear but hard enuff that it moves quickly when it is time to shift.
when it is time to shift all you do is bump the clutch real quick, you are all ready pulling on the shifter so it just jumps into the next gear and the nose of the car may not even drop.
report back after you try it.
<strong> SO DONT LET OF THE GAS AT ALL </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">hold it to the floor brother!!
disclamer...i don't even have a stick, might want to hold off till someone else confirms what i said, that is exacly how i have done it on other cars and from what i understand the 6speed is a prety stout unit and should be able to take it.
<strong> but still have a tough time negotiating the gears.it seems like there is to much effort needed to shift.1-2 is fine....2-3 can be a pig....3-4 your wondering if you put it back to second...and then if im cruising on the expressway and im in 6th if i go for 4th i always wind up in fifth if i speed shift it </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">ok... HUH on that last part??4th is down 5th is up, how do you miss like that? Get a B&M Ripper. How many times have you banged the rev limiter? Speed Shifting is NOT holding the gas to the floorboard, that's power shifting, it's very bad for the tranny and clutch. SPEED shifting is what I do, You are pulling the car out of gear as the pedal is going down, you back off the gas just enough to HOLD the current RPM with no load on the motor, and as the clutch pedal is coming back up you are pushing the shifter into the next gear. It's still a VERY fast shift but takes the load off the tranny, and keeps you from banging the limiter should you miss a shift.
While power/speed shifting....DO NOT MISS A GEAR!!! The magical 3-2 (instead of 3-4) powershift usually makes for bent pushrods and other nasties....just thought I'd mention that. Have fun!
Once you get that down...write back and us M6 guys will tell you how to break the tires loose <img border="0" alt="[burn out]" title="" src="graemlins/gr_burnout.gif" /> from a 40 mph roll on downshift into second.
<strong> Breaking loose at 40...that's easy...find a nice flat stretch of road...Pull the car out of whatever gear you are in and put it into neutral. Let the clutch out. Then push the cluth back in and bring your rpms up to 5,500-6,000rpm put the car into second, pop the clutch and hold on for dear life. </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Your describing double clutching...but, you don't want to raise your RPMs with the clutch in (this causes some components of the tranny not to spin up to the RMPs with the rest of the tranny).
you want to
1.get the car going up to 40mph.
2.push the clutch in and drop the shifter into neutral.
3.release the clutch all the way out
4.hit the gas and rev the engine up so that the RPMs match what they would be if the car was in 2nd gear going 40 mph(basicaly get the rpm over 5K)
5.push the clutch back in
6.drop the shifter into 2nd(it should slip right in if you match the rpm correctly...the synchros don't need to mech)
7.release the clutch(pop it out)
8.floor the gas.
it takes some practice, but once you get used to it it take about 1-2 sec.
