Mini spool
Old Apr 14, 2008 | 10:47 PM
93blacktransam's Avatar
Default Mini spool
ok i have a 1998 formula ....7.5 10 bolt...i took the carrier out of my 1993 trans am so i could use the 3.73 because my stock gears were 2.73 so of corse i couldnt use that carrier..
well two weeks later my carrier took a **** all the bearings and all that were chewed and springs cam out and so on and i have no idea why other than the 90k miles...but anyways can i just put in a mini spool ......as down below...will it be good bad
http://cgi.ebay.com/ebaymotors/7-5-G...QQcmdZViewItem
and is it a 28 spline or 26 spline
Old Apr 15, 2008 | 10:59 AM
Jawsgear's Avatar
Your car will be 28 spline but you need a standard carrier case to install a mini spool. Let me know if we can help you out.
Jeff
