9" with spool ?
Old Mar 17, 2003 | 03:29 PM
sleepersilverado's Avatar
Default 9" with spool ?
ok a buddy has a 9" with a spool. well the prob is that when turning the wholw axle housing shifts and makes the tires rub. I think it is the control arms and wanted to make them solid mount rather then have the polly bushings. prob only make the front bushings solid. what do you guys think about my idea and what the prob is and how to fix it. and yes the finders are trimed.
thanks
Old Mar 17, 2003 | 05:24 PM
The Derek H's Avatar
Default Re: 9" with spool ?
Spherical rod ends might not solve the problem but could resolve a lot of the issue. They do make them with the spherical rod ends on both sides. Check with Thunder Racing. I know they sell the BMR race version with the rod ends on both sides.
Old Mar 18, 2003 | 02:25 AM
any body else ttt
Old Mar 18, 2003 | 11:01 PM
mighty mex's Avatar
spools are different from posi unit diff's.
are you sure its just not the tires skipping because the spool is not letting one tire turn faster than the other in turns???
can you turn the wheels completely, put it in reverse and still have the car move???
Old Mar 19, 2003 | 05:52 PM
no i know the difference and it deas not chirp that much because of soft side walls. the problem is the whole axle housing is shifting due to the high stres of the spool
Old Mar 23, 2003 | 12:07 AM
last of the Z28's's Avatar
im new to this but isnt the panhard bar supposed to stop this? maybee yours is damaged or to weak?
Old Apr 22, 2013 | 11:49 AM
swoop's Avatar
I'm having this same issue with mine also. Did you ever try the solid rod end type control arms?
Old Apr 22, 2013 | 09:40 PM
S10xGN's Avatar
A buddy used to have a pro-street Chevelle with big tires, spool, and ladder bars that would break one of the front rod ends about every other month. Just a bad combination...
