Can I use a 99 Z28 rear end on a 1996 SS?
Old 08-03-2003, 09:39 PM
EddyZ28's Avatar
Default Can I use a 99 Z28 rear end on a 1996 SS?
My rear end is gone on my 96 SS. A buddy with a 99 Z28 has his stock rear end laying around and is giving it to me dirt cheap. Can I use this rear end on my camaro?
Old 08-06-2003, 12:22 AM
99 Black Bird T/A's Avatar
Received 1,434 Likes on 994 Posts
Default Re: Can I use a 99 Z28 rear end on a 1996 SS?
It will fit if that's what you mean. Might want to make sure gears are the same ratio...otherwise you'll need to adjust the ratio change. You can check the code and see what both cars came with.
GU2 is 2.73
GU5 is 3.23
GU6 is 3.42
Old 08-06-2003, 09:09 AM
96blackbeast's Avatar
i have heard that the backing plates are different
Old 08-06-2003, 11:13 AM
kp
kp's Avatar
The whole rear brake assembly is different so that will have to be swapped but thats no big deal - the housing ends are the same. Also it depends on if the rear out of the 99 has TCS or not. My old 2000 rear is under a 94 z28 so it works. He doesnt have any ABS though since my old rear was a 4 channel. The caliper brackets may rub the rotors also, LT1 axles are spaced a tiny bit further out but the last one I did didnt rub..
Old 08-07-2003, 02:18 PM
EddyZ28's Avatar
Thanks for all the info guys.
