Vibration........Not sure what
Old Apr 26, 2008 | 08:41 PM
blue98Z's Avatar
Default Vibration........Not sure what
I just installed a spooled Moser 9" the other day. Everything is great while driving and yes I have all the lights on that everyone else has. Here's the thing. While on my test drive, I stopped and then left kinda hard on it. The wheels broke loose and I let out of it just a little then I felt this bad vibration. Not sure if it's the tranny or rear. Didn't feel like the rear, but I do have the tunnel mount T/A so it could've been the rear and felt like the tranny. I'm gonna bleed the clutch again (cause it's been acting up again) to see if that might be the problem. Any suggestions on what it might be? Did anyone else have this problem afterwards? If so what was it? Thanks for any help or suggestions.
Old Apr 26, 2008 | 10:17 PM
SS1875's Avatar
Maybe you broke your tranny mount or messed up a u-joint. Double check all your bolts and make sure they are tight.... also check the T/A and make sure you didn't break it.
Old Apr 26, 2008 | 10:45 PM
blue98Z's Avatar
Guess I should've included what all has been done. I have a new PST driveshaft, tranny been built, UMI tunnel mount T/A with loop. I think it's the T/A after further inspection, but will do more tomorrow to make sure.
Old Apr 27, 2008 | 06:26 PM
linegtdt52's Avatar
probably the torque arm transferring vibration through to the chasis
Old Apr 27, 2008 | 06:41 PM
blue98Z's Avatar
Yeah that's what I'm thinking. I talked to a buddy of mine the other day that kinda has the same setup and his would do it on street tires as well. Got on it hard today in first and it didn't brake loose and didn't vibrate, so now I'm thinking it was the T/A transfering the vibration of wheel spin. Thanks to everyone who responded.
Old Apr 27, 2008 | 09:08 PM
95GreenZ28's Avatar
Hope you got it figuered out man
