Car pulls to the right or left on acceleration
Old Apr 27, 2008 | 08:42 PM
Jalbert's Avatar
Default Car pulls to the right or left on acceleration
Guy's how come on hard acceleration my car pulls to the right and back off and give it gas again and it pulls to the left it's an 01 SS
Old Apr 27, 2008 | 08:44 PM
95GreenZ28's Avatar
Had it aligned lately?
Old Apr 27, 2008 | 11:00 PM
tylerdj's Avatar
Sounds like you might need an alignment. Have you checked your tires for equal pressure in all of them?
Old Apr 28, 2008 | 12:54 AM
Elliott's94Z's Avatar
Old Apr 28, 2008 | 05:25 PM
Jalbert's Avatar
Tire pressure is good car doesn't pull unless I'm on the throttle hard Just put a new 9" with 4:30 gears replaced pan hard bar and lower contol arms I'm a rag top also? Over 400 rear wheel HP too.
Old Apr 29, 2008 | 07:26 AM
mcflyz28's Avatar
I'm interested here, I noticed it myself with the 9"
Old Apr 29, 2008 | 09:32 AM
95GreenZ28's Avatar
I dont know why the front end would pull though just from a 9" rear
Old Apr 29, 2008 | 09:29 PM
bloodhoundz28's Avatar
i'm also interested i put my 9" in today and i notice the exact same thing
Old Apr 29, 2008 | 10:53 PM
Tally TransAm's Avatar
rear is off center or something is loose and the rear is shifting
Old Apr 30, 2008 | 03:48 AM
RA4926's Avatar
LMAO at people thinking alignment would be an issue if it pulls during acceleration!
do you have adjustable lca's?. are you sure its not the road? grooves or low "channels" in the road will cause a vehicle ( more commonly with wide tires) to pull one way or the other.
Old Apr 30, 2008 | 04:03 AM
El_Diablo's Avatar
I noticed this when I put in my 9". I'd guess it's because I need to properly center/align the suspension. LS1>girlfriend: have you personally driven a car with a 9" that hasn't been properly aligned?
Old Apr 30, 2008 | 07:54 AM
WAHUSKER's Avatar
Which differential are you running? Some types of posi's will do this more than others (lockers for instance are known for this issue) as they try to equalize the torque. And how it was setup will make a difference too. I had a 'clutch-n-spring' type in my 9" that was setup TIGHT & it never pulled, it went absolutely straight running mid 10s!
Old May 1, 2008 | 02:15 PM
IROC test mule's Avatar
If you have a Detroit Locker it's just not fully locked when you accelerate.
Old May 1, 2008 | 03:30 PM
mine does that after the car has been sitting for a while
Old May 16, 2008 | 07:25 PM
SuperSport4life's Avatar
Why would that matter?
Old May 17, 2008 | 02:01 PM
00WS6WHITE's Avatar
I have a 9" with a locker in my car and when you hit the throttle it pulls right/left for a sec till it locks up.
Old May 18, 2008 | 05:51 AM
El_Diablo's Avatar
Well that certainly explains it! Ls1tech makes me feel dumb sometimes. haha
