3" Studs with stock wheels possible?
<strong> My deep socket fits my longer 3" studs fine. I'm using a 1/2" drive which gives the stud some more room. I just wish I could install locks on my 17x11 ZR1 wheels. </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">What brand is that socket you are using?
i cant seem to get the right ones......the first ones i got were too small(arp p/n 100-7701) and then the second ones i got(arp p/n 100-7702) are too big to fit in the axle!!
<strong> </font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by rodent:
<strong> My deep socket fits my longer 3" studs fine. I'm using a 1/2" drive which gives the stud some more room. I just wish I could install locks on my 17x11 ZR1 wheels. </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">What brand is that socket you are using? </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Not sure on brand. I'm using some cheap black impact sockets. I'm at work so I can't look. They seam to be longer than my deep craftsman sockets. I ordered longer studs with my Moser 12 bolt. I'm also using 1/2" studs which are a tad thicker than 14mm.
Anyone have luck with open end locking nuts?
Now that I was thinking about it I was using a 13/16" spark plug socket. I just went and bought a regular 1/2" drive 13/16 deep socket that may work. If it doesn't I'll try a 5/16" spacer behind the wheels. If that doesn't work i'm going to be cutting these wheel studs to 2.75" <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
I went to O'reilly's for lug nuts. They let me go in the back and rummage through all of the lugs they had.
<strong> rodent: what lug nuts are you using on your 1/2" studs? I ordered some 45-degree conical nuts from summit for mine, I think the stock lugs are 60-degree conical though. Any thoughts? </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">You might be right. Might be the wrong nuts I'm using. I thought the angles were the same but maybe not.
I just went to www.gorilla-auto.com and downloaded the catalog in pdf format. Looks like there's some open ended lug nuts/locks that would work.
There's also a 3" long 13/16 thin wall socket you could use. Part # 1316skt.
