additive in rear?
Old Mar 23, 2003 | 02:06 PM
finalymodded's Avatar
Default additive in rear?
Is it necessary to put the additive in the rear or is it ok not to?, also do you have to put additive in before the oil or can you put it in afterwards?
Old Mar 23, 2003 | 03:20 PM
Default Re: additive in rear?
ttt
<img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" />
Old Mar 23, 2003 | 06:08 PM
WJ SOM SS's Avatar
GM says to--it's for the posi chattering issues & such. Put it in whenever convenient, before or after will not cause a big issue...WJ. <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
Old Mar 23, 2003 | 07:21 PM
Thanks man, I was hoping that was the case. I have changed gears and filled it with oil.
Old Mar 23, 2003 | 08:52 PM
trackbird's Avatar
You only need additive with clutch type posi units. The Zexel-Torsen diffs that GM used in the last few years just need gear lube. If you jack up the car and leave the trans in gear, can you spin one wheel by hand? (and the other one turns backwards?) That is either an open diff or a Torsen (Had to mention open diff before someone jumped in to correct me). If it won't move, it is a clutch or cone type and needs additive.
