Guys running 12 bolts step in.
Old 05-28-2008, 04:28 AM
EPP
EPP's Avatar
Originally Posted by Phynix
Exotic Performance Plus has great customer service and some of the best quaility and I can truely say has done a great job with my 12 bolt. my ss puts 613 to the wheels, on occasion I run a 250 nitrous shot(progressive) true trac diff with 4.30 gears, complete bmr rear suspension, with a tex triple disc on my t56, over a year and no noise or problems comming from it, my exhaust is fiarly quiet, I can hear the rocks hit my inerfenders when I have the slicks on driving 5 mph, so there aren't any noises comming from the rear end.
Thanks, I appreciate it!
The way I see it, with the prices between the Moser 12 bolt and nine inch being so close in price, it is clearly up to the customer as to which one they want to go with. I installed a Moser 12 bolt in my '99 Z28 back in 2002 and it was dead quiet until I took it to the track, and launched at 4000 rpm. Ever after that I had gear noise. This doesn't happen with the nine inch. Bob
Old 05-28-2008, 02:46 PM
sedanman's Avatar
Other then the noise from high rpm launches does it last? Or will it break. I got a great deal on a used 12 bolt with 33 spline axles and a eaton posi. Will this hold up to a hard leaving 450rwhp car?
Old 05-28-2008, 03:19 PM
twitchtwice's Avatar
what about he M9?
Old 05-28-2008, 03:37 PM
Dragkid1917's Avatar
what about the h/p loss of a 12 bolt compared to a 9 inch? Is there more drag with a 9 inch then a 12 bolt, because thats what i was lead to belive.
Old 05-28-2008, 06:49 PM
Blackhawk777's Avatar
There is a little drag, but nothing too major. Again, I'm not too worried about picking up gear whine with an auto that won't really run a big stall. The 10 bolt already bit it once, and now I'm saving for something for better insurance than the rebuilt crap under the rear.
Old 05-29-2008, 04:33 AM
EPP
EPP's Avatar
Thumbs up
Originally Posted by twitchtwice
what about he M9?
The M9 is a very strong rear and is the one that I have. It is about the same weight as the 10 bolt to boot. It comes with an awesome torque arm and a transmission crossmember, which gets the torque arm off the transmission.
http://www.exoticperformanceplus.com...html?item=1324
Here is my link to the M9. The housing/axle/torque arm/crossmember package starts at $1,800.00 shipped, then you pick what center section you want from the options. Bob
