Difference between spool and posi...
Old Mar 28, 2003 | 01:46 PM
Sniper33's Avatar
Default Difference between spool and posi...
What is the difference between the two?? What are the pros and cons?? <img border="0" alt="[USA]" title="" src="graemlins/patriot.gif" />
Old Mar 28, 2003 | 01:54 PM
dand35th's Avatar
Default Re: Difference between spool and posi...
spool is solid..posi is basically a limited slip..for any street driving go posi..
<small>[ March 28, 2003, 01:56 PM: Message edited by: dand35th ]</small>
Old Mar 28, 2003 | 02:04 PM
Phate's Avatar
A spool basically locks the two axles together so when one wheel is turning, the other wheel is also turning at the same rate.
Spools are fine for street driving, I have had one in my car for the last 2 years. They tend to tear up tires a bit faster and make a little more noise going around turns.
On the positive side...you will probably never break it, spools are lighter then posi units, and the car feels more 'predictable' to me. What I mean by this is if I am getting sideways with the spool I can back out of it a little and the car will straighten itself out pretty much on its own.
Scott
Old Mar 28, 2003 | 02:18 PM
Sniper33's Avatar
Thanx guys! Any actual performance differences or are they the same?? How about fuel consumption between the two?? <img border="0" alt="[USA]" title="" src="graemlins/patriot.gif" />
<small>[ March 28, 2003, 02:19 PM: Message edited by: Sniper33 ]</small>
Old Mar 28, 2003 | 02:42 PM
gwj's Avatar
gwj
From: Live Oak, FL - in the woods where the creatures lurk.
Well...it's really strange turning a corner for the first time w/a spool!
Old Mar 28, 2003 | 06:07 PM
Phate's Avatar
Well, fuel consumption would be minimally different...I guess the spool would be a little better because of less rotating mass, but it is probably no measurable difference.
Performance wise, spools are great for drag racing...probably not so good for Auto-x (although I am not sure about this).
Scott
<small>[ March 28, 2003, 06:09 PM: Message edited by: Scott 98Z M6 ]</small>
