Gear ratio help
Old Mar 28, 2003 | 03:39 PM
Blk98Bird's Avatar
Default Gear ratio help
Hey guys I was wondering if anyone knew where I could find and compare the ratios for each gear on an m6 with 4.10's and one with 3.43's. Both in stock 10-bolt. Or if you could just post up the info, that would be great as well.
Thanks!
Old Mar 28, 2003 | 03:46 PM
BoneStock's Avatar
Default Re: Gear ratio help
Go to this site. They have a gear calculator that gives you an rpm and mph relation.
http://www.drivetraindirect.com/html...ramehome3.html
Will
Old Mar 28, 2003 | 05:17 PM
Blk98Bird's Avatar
Thank you but what i'm looking for exactly is what the actual multiplying ratio is for each gear. See, my issue is that I live around chicago and the winters get real rough so first gear is totally useless usually and i'm forced to second gear starts. I'm trying to see if the gearing ratio is too steep in second to get any traction if I have to drive in the winter.
Old Mar 28, 2003 | 05:29 PM
Brownie's Avatar
www.f-body.org/gears
