Hurst Shifter, reverse in a pain
Old Mar 29, 2003 | 10:59 PM
SSpilot's Avatar
Default Hurst Shifter, reverse in a pain
'02 LS1 with a Hurst shifter from the factory is a real pain in the *** putting it into reverse. Any help or thoughts would be great.
Old Mar 30, 2003 | 12:51 AM
SS 414's Avatar
Default Re: Hurst Shifter, reverse in a pain
Push the clutch down. <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
I really have no idea. I've never had a problem with mine unless it's really cold out.
Old Mar 30, 2003 | 01:31 AM
CostaZ06's Avatar
Mine is the same on my 02 Z06 Corvette. I have the stock shifter and when you put it in reverse it dosen't go all the way in and when you let off the clutch it grinds. I have to play with it to go in with out grinding every time I wanna back up! <img border="0" alt="[bang head]" title="" src="graemlins/gr_banghead.gif" /> <img border="0" title="" alt="[Mad]" src="gr_images/icons/mad.gif" />
Old Mar 30, 2003 | 08:20 AM
edss01's Avatar
My 01 ss does the same thing I have found if you put in the clutch stick it in 1st then go to reverse and it will go right in,otherwise it seems a little hard to go in reverse.It will go in without doing that but is kind of hard to get in.
Eddy in Iowa <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
Old Mar 30, 2003 | 09:06 AM
2001WS-6's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by edss01:
<strong> My 01 ss does the same thing I have found if you put in the clutch stick it in 1st then go to reverse and it will go right in,otherwise it seems a little hard to go in reverse.It will go in without doing that but is kind of hard to get in.
Eddy in Iowa <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" /> </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Yup, have the same problem. I found by doing the same procedure that edss01 said you should have no problems. <img border="0" alt="[cheers]" title="" src="graemlins/gr_cheers.gif" />
Old Mar 30, 2003 | 06:28 PM
Xsta Z 28's Avatar
Moving to "Drivetrain"
Old Mar 30, 2003 | 08:37 PM
InvisibleSun's Avatar
edss01 has it nailed. I have to do this at least a few times a week to get it into reverse smoothly. And I'm having more and more trouble getting it into 1st, now. It seems when I first got the car (10K miles now) I had to only rev the engine or drop it into second first to get it into first once in a while, now I have to do it all the time. Even then I have to give it a little harder push to get in gear. Maybe my clutch is going... <img border="0" title="" alt="[Roll Eyes]" src="images/icons/rolleyes.gif" />
Old Mar 31, 2003 | 12:56 AM
waverider's Avatar
Reverse is a direct gear with no synchros. All manual trans are like this so you have to go into another gear before going into reverse.
