fair price for gear swap?
I dropped off a Moser 12bolt that worked perfectly to a driveline shop to get the gears changed to 4.11's. I also included a Moser set-up kit with new bearings.
What do you think is a fair price to have all of this installed? They originally told me $236, but now that it is done they are telling me it came out to $430. Is that right?
Thanks!
Thanks!
Thanks!
Thanks!
This is why I usually do all of own work.
So....what was the reason for the big jump in price???
Regardless of who did it, or how good their reputation is, $430 is a bit high no matter what...especially with doing the job on a rear that isn't even in a car...
I rebuilt a buddy's stock 10 bolt a few weeks ago. (no different, just slightly smaller, obviously)
New Motive ring & pinion
New carrier bearings
New pinion bearings (inner & outer)
New pinion seal
New axle bearings
New axle seals
He supplied all parts. I supplied labor, gear oil, rtv, etc...
The rear was still in car, I don't have a lift here at the house so I quoted and charged $300...basically a hundred bucks an hour, because that's what I felt the job was worth, regardless of how long it took me. Drivetrain rebuilds are what I do for a living, so I did it as a favor, more or less. The rear's done right, it's dead quiet, and he's happy...
To nearly double the charges on what should be a simple job for a shop who knows what they are doing, is BS imho...
New pinion seal
New axle bearings
New axle seals
