8.8 or 9 inch fab info.
Old 08-15-2003 | 02:09 AM
ssdungeon's Avatar
Default 8.8 or 9 inch fab info.
I would just like to find out what vehicle I need to look at to find an 8.8 or 9 inch to use to fab my new rear end using my 10 bolt. I was guessing the 88 and up mustangs but I need advice from those that know. I am sure someone else can benifit from this info.
Thanks,
Old 08-15-2003 | 04:00 AM
silverTA's Avatar
Default Re: 8.8 or 9 inch fab info.
86 and up stangs V8 came 8.8
,i don't know what kind if mod u need to do to make it fit our cars ,,, go there to see some used rear end
http://stangparts.com/home.cfm?section=products/index
Old 08-15-2003 | 03:09 PM
Screamin_Z's Avatar
ur not going to be able to "fab" a rear end up unless u have alot of experience in custom metal fabrication. It's ALOT harder than most people think. The guy who built a 8.8 for me showed me step by step how to do it and there are jigs u need, u need to make sure everything it "plum" the angles are just right, ect. I'll send u a PM on the guy who builds the 8.8 for our cars.
Old 08-27-2003 | 11:37 PM
Gofast's Avatar
SS,
Are you looking for someone to build you something like a chromoly Fab 9" rearend for your car? Like the pic. below? Or something OEM because I do have a guy that can build ya a Fab 9"?
www.gofastzone.com/members/The%20KING/012_21a.jpg
Old 08-28-2003 | 11:07 AM
Pro Stock John's Avatar
LS1Tech Co-Founder
A chassis guy could set one up but you might not be saving any money but you would have a nice custom rear end.
Old 09-03-2003 | 07:19 PM
991LE's Avatar
The only thing that irritates me is that the people that have the 8.8 treat it like you have to understand black magic to be able to get the 8.8 to work in an f-body. If you aren't going to share how you did it, then shut the f up.
Old 09-04-2003 | 02:23 AM
Screamin_Z's Avatar
I didn't do it, I had someone build me the rear end. I don't understand how it was EXACTLY done. all I know is it was build in a jig and it took the guy several weeks to get EVERYTHING right i.e. the pinion angle, TA mount, axle tubes, ect. If u want to know how it was built then ask him. Also, he has secrets on how he did certain things that makes his better than anyother 8.8 built.
