"Need help" Torque arm won't fit, plus another screw up lol.
Its an Edelbrock stock replacement "non-adjustable" T arm, it fit the 10 bolt fine, but it won't fit the 9" T arm Bracket, what arm will fit these, do i need an adj. arm?
Also, i think i screwed up with the Caliper brackets when i had the axles bearings installed , they are faceing towards the front, not the rear, i knew i should have takin pictures, can anyone help!
Well hopefully/maybe i didn't mess up on the caliper brackets, i got to looking at some pix & can see the calipers are towards the front, but i still need to figure out this torque arm issue.
Yeah, i noticed i would have to really modify the Edelbrock T arm too much, then it wouldn't be worth a hoot. I was hopeing i wouldn't have to shell out for another T arm, especially an adj. one.
About the Caliper brackets, does anyone have a pic of how the calipers will be positioned in the rear? Thanks
