Need help transmission problems
Old Apr 5, 2003 | 06:36 PM
JRcamaroZ28's Avatar
Default Need help transmission problems
Today when i was comming home my SES light cam on so i scaned it w/ A-Tap and got the P0803 skipshift selonoid code. Now when it should shift from 1-4 i can now go 1-2 (which is no problem for me since it saves on the skipshift eliminator) but i want to get rid of the light. I'll probly have to replace the selonid if its the only way to turn out the light. i checked all the connections and there are no broken of burnt through wires. How can i check if the selonid is bad? Also my other problem is that it is very tough to shift into reverse since this has happend today. I have the PRO 5.0 shifter now. This all happened when i was just driving down the road. no harsh abuse at all to the trans. so i really dont know what could have caused this to happen.
JR
Old Apr 6, 2003 | 05:37 PM
Default Re: Need help transmission problems
traced it back to a blown engine sensor fuse. my MAFT went bad and blew it out. Took MAFT off and now it works so hopefully thats it
JR
