Moser 12 bolt rear problems
Gears are an issue. I am now running a set of 1964 GM gears. They are pretty loud when I lift at the end of the track but are usually quiet by the end of the return road.
I will probably go to a 9in in the next year or so and put this one in my wifes car.
BTW I had mine built and maintained localy
I've had it suggested to me to take it to a local shop with a good reputation for setting up rearends and have them take a look at it. This is on my list of things to do.
I got my 12-bolt for much the same reason you did: I wanted to retain ABS. It sucks that this is what we have to do, but after doing a lot of reading and research, along with asking people who owned these rearends, I came to the conclusion that this is all part of the aftermarket parts game. Some manufacturers' parts bolt right in, while others require extra effort.
However, I don't think pursuing legal action for selling a defective product really fits here. Besides, they can always just rely on the "it isn't OEM, so you can't expect it to fit like OEM" card.
-Mike
For your 12 bolt I would just tack weld the nuts to the bolt threads once you have them tight, it's quick and easy, and you won't have to worry about them again. Bob
People have tried multiple methods to fix this problem with varying results - the only true fixes seem to be those that involve some sort of physical retention device like safety wire or tack welds. Loctite and locking washers aren't the answer, and you can't just drill the holes out to convert it to a through-bolt setup since you'll end up drilling right into the housing itself, causing a big leak.
the sheet metal would be similar to this http://cgi.ebay.com/ebaymotors/ws/eB...d=180532378942
