17" vs 18" wheels
Old Apr 10, 2003 | 11:50 AM
oOoLy's Avatar
Default 17" vs 18" wheels
I have camaro 98/M6 my mods in sig!! my wheels is ZR1 the front 17/275/40 the rear 17/315/35 i change it with C5 01 wheels the front 17 and the rear 18/275/40 the question is!
What will happen at my RPM and distance, weight did it different or same?
Note: i want it for street racing about 800m
Thanks
Adnan
Old Apr 10, 2003 | 02:49 PM
someday's Avatar
Default Re: 17" vs 18" wheels
with tires that r about an inch taller, ur car will think u have 3.59 gears in it now... ur rpm's will be about 4% lower at any speed... also be sure to adjust ur LS1 edit with the new tire size: 26.66" vs the 25.68" of ur 315's... also, u have LS1 edit listed twice in ur sig...
Old Apr 11, 2003 | 08:52 AM
oOoLy's Avatar
Thank you someday for your reply ...... <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
If i adjust my new tire size with the ls1-edit the RPM will be good or i will be about 4% lower at any speed ?
It's a good idea to change my 18" tire to 16" or not ?
Thanks
Adnan
Old Apr 11, 2003 | 05:13 PM
someday's Avatar
adjusting the computer will keep your speedometer reading correctly, but your rpm's will be lower... like if u had 3.59 gears, instead of 3.73's... u might want to change the back tires to a 285/35x18, which is 25.85" tall, or only about 1% different, equaling about 3.69 gears
<small>[ April 11, 2003, 05:18 PM: Message edited by: someday ]</small>
Old Apr 13, 2003 | 02:56 PM
oOoLy's Avatar
So do you advice me to stay with the 18" or go to the 16" for street racing for about 800m ?
Thanks
Adnan
Old Apr 13, 2003 | 11:28 PM
someday's Avatar
it all depends on how hard u need to launch in that race, it sounds like a long race, so topend may be more important... i'd stay with the 18's, and if u spin too hard off the line, then change them...
