SLAVE CYLINDER ?????
can bore the restriction from the factory setting of .063" to .125" for quicker and smoother engagement of the clutch bearing . also makes for less force needed in the clutch pedal
<strong> OM MY 2000 Z28 M6.... DO I NEED TO CHANGE MY SLAVE CYLINDER??( TO WHAT YEAR) BECAUSE I'M UPGRADING TO A Z06 CLUTC.... OR IS THERE A WAY TO MODIFY THE STOCK ONE. IF THERE IS A WAY TO MODIFY CAN YOU PLEASE LET ME KNOW HOW.. </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">The newer slave and master cylinder came on the 2001+ cars. I would buy the newer slave and at the minimum do the drill out mod on your 2000 master cylinder. I put a 01 Z06 clutch in my Z28 about 2 years ago with a 01 slave and kept my old stock 98 master cylinder. The hydraulic never felt right in my opinion. It engaged too close to the bottom. Just recently I put in the 01+ slave, 01+ master cylinder with the drill out mod, and a Spec III clutch. I must say the hydraulic feels awesome compared to before. No telling how much better my previous set would have been with the drill out mod. I would recommend the drill out mod no matter which master cylinder you use.
<strong> How did you guys bleed the clutch after you did the drillout?? Also, how far did you guys drill down the line with a 1/8 drill bit? I drilled down about an inch or little more and cant get peddle pressure as of now! any info appreciated!! Stock 01" clutch and master! </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Yes, I used a mighty vac to suck/flush the metal shavings out and also bleed it with the mighty vac.
I pretty much drilled further then I expected, from what I read, until the bit was able to slide in and out with no issues. I was surprise at how far my drill bit went in. Shoot me an email at texastech97@yahoo.com, and I'll send you a couple of pictures of how far my drill bit went it. Another thing I did was stepped up on the bit sizes to work the restriction larger and larger.
<small>[ April 13, 2003, 12:38 AM: Message edited by: Go Texas Tech ]</small>
