Mobil 1 ATF - Yes or No ??
I changed my tranny fluid about two weeks ago with Mobil 1 ATF replacing the original Dexron fluid. It seems that the transmission now shifts A LOT smoother than before. The shifts before were a lot crisper at part throttle and now have smoothed out. I assume that is because the fresh Mobil 1 ATF is slicker than the old fluid.
What are your experiences? Has anyone here had problems with Mobil 1 ATF and switched it back out??
Re: Mobil 1 ATF - Yes or No ??
With a converter swap and filter change, I ran total Mobil 1 ATF in my old 98 Z28 from March of 1999 till I traded the car in October 2001. Around 40000 miles. Also I had no additional tranny cooler. No problems. It was a relatively small 2800 Yank converter though. Mike at Yank converters was the person who did the install.
Les
Les
