question about Caliper Bracket , help please
Old Aug 22, 2003 | 03:57 PM
FireHawk22's Avatar
Default question about Caliper Bracket , help please
Hi,
I got my new moser 12-bolts for my firehawk 2000 , it came fully assambeled ..... but I noticed that it came without Caliper Bracket , when I called MOSER , they told me that I can use that one that in my stock GM 10-bolts rear end .
So , what I want to know , is that right ? can I use that caliper bracket that come with the factory stock one ?
if I used this GM caliper , whats can hold the exsles inside the rearend ? is it the caliper ? or their is another thing that I have to install it to hold the exsles ?
Thanks in advance
Old Aug 30, 2003 | 07:16 AM
FireHawk22's Avatar
Default Re: question about Caliper Bracket , help please
now won have any emfrmaion about it
Old Aug 30, 2003 | 04:23 PM
42NightZ28's Avatar
12-Bolt axles are held in with C-clips same as a stock 10-bolt is. (unless you ordered the c-clip eliminter package on the 12-bolt) in order to remove the Calipers from the 10-bolt pull the diff cover and spin the diff till you see a block with 1 small bolt holding it in. Undo the bolt and remove the block. Now press in on the axles from the studs on the axle ends and the c-clip for that axle will come out, then remove the axles. Next you can unbolt the brackets and install them on the 12-bolt
Old Sep 2, 2003 | 05:25 AM
FireHawk22's Avatar
thank for your helpful.but what i want to know how can i install it step bay step because i don't have any information about the rear end .and am taking from overseas.and in my country their is no good garage so if any wan can tell me the steps to install the rear end i will be thank for him....
thanks...
Old Sep 5, 2003 | 04:53 AM
FireHawk22's Avatar
now own can help me for that
