Diffrence between axels
FYI...
My experience has been that LT1 axles will fit LS1 rears, however the bolt pattern and stud length are a little different, and factory LS1 rims will not mount without some grinding mods. to the center hub opening and proper length studs.
LS1 axles should fit an LT1 rear without issues, other than possible stud length adjustments.
I have not idea about 6 cyl axles, but I would not install in an LS1 or LT1 car if they were visually different... in other words not as beefy. Broken axles are no fun, especially c-clip axle designs.
