Strange 12 bolt ?'s
Old Apr 21, 2003 | 09:02 PM
GateKeeper's Avatar
Default Strange 12 bolt ?'s
I have an '02 TA with TCS. Im thinking about getting a Strange 12 bolt. But I have a few questions I thought you guys might be able to answer.
1) Im thinking about getting 33 spline axles but I read that if I want to maintain my TCS I need to send them my axels? Why is this so? Im buying new axles why do they need mine?
2) Can I just screw the TCS and not send in my axles? I would imagine some codes will be thrown, but i guess they can be deleted with edit. Is this ture? So in this case, what channel ABS ring would I want? Can I even do this?
3) What is this reluctor ring... is that for ABS/TCS?
4) Do these rear come with all the mounting brackets... sway bar, LCA, etc
5) Do Strange rears come with pressed-on bearings,or OEM style c-clip axles?
Thanks for the input.
Old Apr 21, 2003 | 11:32 PM
buschman's Avatar
Default Re: Strange 12 bolt ?'s
You don't have to send them your axles, but they need the relucter rings off the 10 bolt axles. Take the axles to a local shop with a bearing press. I had my rings pressed off for $20. Then you can send Strange your rings and backing plates and save the hassle and expense of sending the axles as well.
Mike
<small>[ April 21, 2003, 11:33 PM: Message edited by: buschman ]</small>
Old Apr 22, 2003 | 08:59 PM
Slowhawk's Avatar
LS1Tech Sponsor
There is a company that sells just the reluctor wheels by themselves.I forget who but think it's Billingsly racing?
