guys with 9 inch and conversion u joint come in
Old Jul 26, 2008 | 02:57 PM
noregretz999's Avatar
Default guys with 9 inch and conversion u joint come in
Did you reuse your stock strap and drive shaft bolts?
my bolts are too short can I just get longer bolts or do I need different straps as well?
thanks
Old Jul 26, 2008 | 03:13 PM
http://store.summitracing.com/partde...5&autoview=sku
is this what I need?
anyone know a part number for napa or something I'd rather find them locally
Old Jul 26, 2008 | 08:18 PM
CW00BlackTA's Avatar
Didn't the 9 inch come with straps and bolts? You should have new ones for the large sides of the joint and use the stockers for the stock side.
Old Jul 26, 2008 | 08:55 PM
If it did then I lost them where can I get some
Old Jul 26, 2008 | 09:32 PM
linegtdt52's Avatar
go get the straps for a 79 series bronco actually I think it was whatever car had the 9" in it maybe the continental those are the straps you need i had the same problem
Old Jul 30, 2008 | 11:44 AM
Vicious95Z28's Avatar
Out of curiosity, where is a good place to get those new or did you go junk yard diving?
