short stick?
Old Apr 24, 2003 | 10:15 AM
last of the Z28's's Avatar
Default short stick?
ive read about the after market shifters. personally i have no problem shifting my plain stock one. my ? is has anyone put a short stick on their stock NON hurst shifter? any improvement? thanks.
Old Apr 24, 2003 | 10:36 AM
bodhi's Avatar
Default Re: short stick?
Lou's short stick kicks ***. I had a LSS on my stock hurst shifter- there is no comparison.
but don't waste the $50. Just do it right the first time and buy the Pro 5.0 and LSS (only LSS others are a joke).
Afterthoughtsauto.com has the complete kit with the Pro 5.0 and LSS for $215. It doesn't get any better than that
Ls1speed will try to sell you their short stick for the pro 5.0- don;t waste the time it is a complete POS.
For the Pro 5.0 you need a bend in the handle to properly align everything. LSS has this down. The one Ls1speed pawns off is nothing more than a piece of cheap barstock with threads and two holes drilled.
Old Apr 24, 2003 | 10:30 PM
lastSS's Avatar
I have LSS and I could not be happier. I also have the factory Hurst, but the improvement was great. I assume that it wouls also be great with the factory shifter.
<img border="0" alt="[USA]" title="" src="graemlins/patriot.gif" />
Old Apr 24, 2003 | 11:49 PM
trackbird's Avatar
I did a B&M ripper and removed a factory Hurst....it was teh best money I ever spent (and getting rid of the stock shift **** that "spins" on hot days iw well worth it. I used a black Hurst **** with the 6 speed shift pattern on it and a jam nut....problem solved!!!). Just my experience. GOod luck!
