what is ABS worth to you?
Old Aug 2, 2008 | 07:26 AM
Striped02WS6's Avatar
Default what is ABS worth to you?
it seems every good deal i find i have to sacrifice ABS becuase its a 4 channel rear and my car is a 3 channel car...or i have to pay more when ordering a brand new rear....
i cant bring myself to buy a rear thats not going to retain my ABS even if i can buy it for 1200 dollars less then what it would cost brand new....
ahhh so heres the question...how much savings would it take for you to for go the ABS option...
well?
Old Aug 2, 2008 | 08:57 AM
Black02SLPSS's Avatar
4 channel means it supports TCS. It just has 2 wheel speed sensors instead of one like the 3 channel. If its a 3 channel it will retain your abs.
Old Aug 2, 2008 | 08:59 AM
CaMaRo67RS355's Avatar
i say screw abs take it out and its less weight
Old Aug 2, 2008 | 09:33 AM
02SS:ZEUS's Avatar
You don't need your abs. I had a 3 channel rear, and went to a 4 channel...like you said, I got a good deal. Just make sure you pull out your ABS fuse if you do go that route, or you may end up losing your brakes like I did. Then pull out the guage cluster a just enough to get a needle nose pliers back there to pop the ABS light.
Old Aug 2, 2008 | 12:21 PM
pddye's Avatar
I haven't had ABS in any of my cars for more then 2 years. I stop just fine.
Old Aug 2, 2008 | 12:30 PM
cool...thats really what i wanted to hear from everyone lol....my last car had abs however the 3 cars before that didnt have it and i never had a problem with them....how did you loose your breaks from not pulling the abs fuze?
Old Aug 2, 2008 | 01:20 PM
BriancWS6's Avatar
**** ABS, **** TCS/ASR. I just dropped over 4k on a new M9 and some suspension components, and I didn't get 4 channel-ON PURPOSE
Old Aug 2, 2008 | 04:52 PM
ZeeTwentyFate's Avatar
ABS almost got me killed wwhen the block up front malfunctioned and rolled me into a 4 way intersection. i was at home taking all that crap out the next day
Old Aug 2, 2008 | 06:19 PM
keliente's Avatar
I personally like it...and would pay to keep it...it's not so much the ABS I'm after, but the traction control (which you can't have without ABS). I daily drive my car, the power can sneak up on me with the turbos...but TCS keeps me straight
Old Aug 3, 2008 | 02:45 AM
02SS:ZEUS's Avatar
I'm not sure why it was doing it, but the car was trying to figure out why the abs wasn't working. I would push the brake pedal to slow down, and it would damn near hit the floor, then start vibrating, and the ABS light would come on, but there was hardly any pressure going to the brakes. This was immediately after switching rear-ends. I pulled the ABS fuse, and everything was fine. A few other people on this board have had the same thing happen. So make sure you pull the ABS fuse when you switch rear-ends. With the fuse pulled, the ABS system is completely turned off....not half-way turned off because it's not hooked up to the rear-end.
Old Aug 3, 2008 | 12:33 PM
LS1-STANG's Avatar
USELESS its no good even with a stock rear The minute you change tires 26" front 28" rear... it goes crazy
Old Aug 3, 2008 | 05:17 PM
MeentSS02's Avatar
Kleeborp the Moderator™
If I was using my car for a daily driver, I'd keep the ABS/TCS, no questions asked. It isn't your driving ability in question...it is the ability of the idiot that just pulled out in front of you on a rainy day that you couldn't help.
That being said, I purposely ordered my Strange 12-bolt with no ABS/TCS provisions, and haven't looked back since. The car is a nice weather only/weekend only car.
