What tire size and offset for narrowed 12 bolt?
Old 08-13-2008, 02:21 PM
lower_the_dynamite's Avatar
Default What tire size and offset for narrowed 12 bolt?
I'm looking into buy a narrowed 12 bolt that has been shortened 3" on each side. It has fit into a 4th gen lt1 car and has all the provisions for LCA's, TA Brakes ect. Right now I have a 15/8 welds with a 5.5 backspacing. If the rear end is narrowed 3" on each side, and I want to run a 10" rim, will a 15/10 with a 3.5 backspace be okay? I want this to go in with no cutting of anykind. Let know what you think. Thanks in advance.
Old 08-15-2008, 11:31 AM
01RedZ28's Avatar
15x10 with 5.5 backspace will tuck in about an inch with the rear narrowed 3in.
Old 08-15-2008, 01:41 PM
LS1Tech Sponsor
Scott@DrivelineSolutions's Avatar
On a standard 10 bolt you will have a 7.5" back spacing on a Weld rim. If you housing is narrowed 3" per side then I would test fit a set with 4.5" of back spacing. Most tire places will only let you test fit the rim without a tire mounted.
Quick Reply: What tire size and offset for narrowed 12 bolt?
