Strange 12 bolt whine
Kleeborp the Moderator™
Yes...most of this is subjective and people throwing out guesses. I can assure you that the gear pattern in mine is messed up, and causing a LOT of my noise. I'll be resetting the gears next spring and see what I end up with. For right now, I'm just driving the **** out of these noisy ones since I'll be tossing them anyway.
The 9" torque arms are usually mounted to the housing itself differently. They use a big, beefy bracket that does not bolt anywhere close to the pinion gear like the 12-bolts do that have the mount cast in to the housing.
Actually, Moser claims they use the four shorter bolts to make the housing stronger since they aren't punching holes through the entire housing like Strange, but their design sucks from a practical standpoint unless you really like safety wire.
I see what you're saying. I also realized later that you have a Strange 12-bolt yourself, so you already knew how the torque arm mounted. The way you described it, it sounded like you meant that the two bolts go through the housing itself, rather than those plate protrusions to the side of the housing. No biggie anyway.
But that is why Moser uses four blind holes instead of the through holes like Strange's 12-bolt...they want as much metal in the housing for structural support at the expense of a ****-poor fastener design. Oddly enough, the Moser 9in. housing uses two through bolts instead of the four blind holes like their 12-bolt...
If I had to do this all over again, I would have probably just gone through Mark Williams for my 12-bolt...at least then I would have known it would be right straight out of the box. I am looking forward to learning how to set up gears though...at least I'll know it was done right this time around.
Indeed...now that I read it again, it does make it sound like the bolts go through oil and gears before coming out the other side. Definitely not the case there
Yes, knowing how to setup gears would be a valuable skill to have under your belt. You'd probably pickup a lot of new racing friends too. Do mine! Do mine!
#32
Oddly enough, my 10-bolt whined louder than my Strange does now straight from the factory. I kept getting the runaround from the dealership "Oh, it'll be noisy...it's a performance axle." It took a different dealership 4 tries to get them set up right, but it was finally stone silent after that.
I've had horrible luck with axles thus far...I probably could have prevented this one had I just run a quick pattern check before I installed it, but I got impatient.
#33
By any chance, are you heavily into 5k launches, or is it just bad luck?
#34
The car has never seen a drag radial in its life, and I've never launched over 3000 RPMs, and even at that, my tires always spun (to a scorching 2.1 60' ). The 10-bolt was noisy from the day I drove it off the dealership's lot...really, it is just bad luck. Even with the 12-bolt, I still have never launched it, and it still rides on BFG KDW2s.
#35
Funny you should mention that...
Nice talking to you! And GOOD luck in the future.
#36
These rearend experiences are so subjective, I'm learning that it's futile to post individual experiences. I see your point, maybe I mean when the engine gets into the power band it seems noisier, I'm not sure though.
All I know for sure is that my 12-bolt is noisier than my stock rear, not in an annoying way, to me anyway, and I expected it to be a noisier, and I can't see how it couldn't be noisier than a 10-bolt. Everything is bigger, the gears, all the moving parts. Also, I find that my rear sounds different everytime I drive the car. I've only put a couple hundred miles on mine, so I'm still learning its characteristics.
It seems that a discussion about aftermarket rearends is steeped in subjectivity, and I'm having a hard time defining what the facts are. I think in the future I'll stick to topics that lend themselves to facts.
So what do you think is causing your rear to be noisier after trips to the track? What's your theory? Thanks.
#37
Well, "beating the **** out of it" doesn't explain the exact cause of the noise. This is what I mean by subjective. Maybe someone else would call it normal driving. Everyone see things differently.
#39
My Strange 12-bolt was dead quiet when it was new, took it to the track and picked up noticeable gear whine. Keep in mind this is an A4 car launched at 1500-2300 rpms off the footbrake.
#40
Thanks for all of the info everyone. I can live with the noise it is no where close the sound of my stock with the richmond 373 I had in it. I replaced the bearings, axels, ect... in the stock and it never got quiet. I took the car to 3 shops and all said the pattern was fine. I am going to change the fluid with royal purple I dont think it will make a difference in the noise but it is due. Do you change the oil in these just like the stocker (fill it till it is full) or do they require a certain amount? Is there a drian plug. Sorry for the questions I helped a friend change his once but I ended up drinking more beer than helping. Thanks for any info.
